September 12, 2019 at 9:26 pm
mmy3147
SubscriberHello all,
I am trying to get a frequency response of an arbitrary room using ANSYS 2019 R1. Unfortunately I have not found any guides pertaining to the new acoustics module and all are based on the older ACT acoustics.
Currently I have set up a room with a speaker in the middle at around human height, and I am using an incident wave source with a back enclosed speaker. Trying to simulate a human singer. Most tutorials use mass source however I am using this source since I am able to position it at different places, it looks like it is no longer possible to place a mass source on a node.
I have two questions, first, what is the idea behind the radius of pulsating sphere ? does it indicate the size of the speaker driver ?
Also in the simulation, the frequency response becomes flat after 2500 Hz , while I am trying to attempt a full response curve from 0 - 24k Hz. Is this due to the coarse mesh or is there an issue with the boundary conditions I have set up ?
I have attached the project file here.
Thanks in advance for your help.
2074
1289
1106
459
