November 3, 2018 at 4:56 pm
sameerfares
SubscriberHi All,
What is the difference between a body or a solid and a component ?
Sam
November 3, 2018 at 5:40 pm
SubscriberHi Sam,
A body can be a surface or a solid and that is geometry. A component is a collection of bodies that can be moved or hidden as a group and multiple components make up an assembly.
Peter -
November 3, 2018 at 10:04 pm
sameerfares
SubscriberThank you Peter!
November 4, 2018 at 4:13 am
FrankD
Ansys EmployeeSam
Think of a Component like a holder or folder. It can contain bodies (surfaces and solids, and points, and curves, things you can see and touch) and be contained in other Components, either in the design document (the scdoc) as an internal component -- or linked to an eternal component (another scdoc file)
Having a holder like this allows you to make a separation between the active bodies you want to model and modify, and others that are not supposed to be adjusted by modeling operations.
F
November 4, 2018 at 8:31 pm
sameerfares
SubscriberThank you Frank!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2146
1357
1150
462
