September 1, 2023 at 2:07 pm
Muhammad Aditya Nugraha
SubscriberI have read several references on the internet. I just want to make sure if the references I've read are valid or not.
In static structural analysis, what is the fundamental difference between "Force" and "Remote Force"? How is the illustration of their difference in the real world problem? Big Thanks
Saya sudah membaca beberapa referensi di internet, di sini saya hanya ingin memastikan apakah referensi yang saya telah baca itu valid atau tidak.
Dalam static structural, perbedaan mendasar dari "Force" dan "Remote Force" itu apa ya?. Bagaimana ilustrasi perbedaannya jikalau diilustraikan dalam permasalahan nyata?. Terima kasih
September 1, 2023 at 2:09 pm
Raihan Lutfianto
SubscriberHi Aditya, that's a really good question. The main difference between Force and Remote Force is how you apply the force. In Ansys Mechanical, Force can be applied directly to the body, while Remote Force uses what so-called remote point, and this remote point can be adjusted (xyz coordinate).
Typically, we use Remote Force to represent a complete system, but we want to minimize the computational cost by not including some components in our FEM model.
You can also refer to this Difference between Remote and ordinary displacement/force constraints (ansys.com)
September 1, 2023 at 2:20 pm
SubscriberI see. So the difference is about how they are affect object motion at DOFs. The Remote Force constraints the object motion at some DOFs (as we want it). Thanks for the explanation (and also the reference), Kak
September 1, 2023 at 2:21 pm
Raihan Lutfianto
SubscriberKeep it up, Aditya.
- Features of the check case
- Room with Air-Conditioning Vents
- Error Floating Point Exception
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Heat transfer radiation through glass
- real fundamental difference in true tension body and engineered tension
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Viscous Models
- Convergency in mass flow rate
- Torsion Stiffness
7818
4514
2979
1453
1322
