August 17, 2022 at 6:50 am
liguangrui33
SubscriberDear Sir or Madam,
I am trying to simulate imaging of a periodic structure. While using gratingpolar function I can have clear diffraction orders on the far field, using farfieldpolar I saw oscillations from the diffraction orders in direction normal to the boundary of the simulation region. My question is what is the physical difference between gratingpolar and farfieldpolar functions beside normalization of the sum(|E|^2) with gratingpolar?
Thank you.
August 17, 2022 at 8:38 pm
Guilin Sun
Ansys EmployeeWe have dedicated Photonics Forums:
You can also add them to “My Channel” by clicking the “+” of the icons at the top right corner:
Grating analysis scripts assume infinite number of periods, thus it uses plane waves for the decompision of the monitor data.
farfield script is for non-periodic structure, and it uses the standard near-2-far transformation in FDTD community. You may find a book chapter by searching
Chapter 14
Near-to-Far-Field Transformation -
August 17, 2022 at 9:06 pm
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- How to calculate the cross-polarization efficiency and phase in FDTD
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2600
2088
1319
1108
459
