February 4, 2021 at 8:08 am
psansys
SubscriberHi all,
I wanted to apply a sinusoidal displacement to an assembly and while using harmonic analysis, I am getting max. stress values as low as 6e-6 MPa. I came across the idea of remote displacement and selected the non-fixed surfaces to apply the remote displacement values (static structural) tabulated from sine function.
eg:
February 4, 2021 at 4:29 pmHuiLiu
Ansys EmployeeHarmonic analysis is linear dynamics, while static isn't accounting for dynamic response. Comparable cases would be transient case with sinusoidal displacement applied so you have time integration. Note that in static there is no time integration though there is the time column on the tabular data.nFebruary 5, 2021 at 3:53 ampsansys
SubscriberThank you for your fast response. I hope that means, each time step acts as an independent static analysis unlike in harmonic where the effect will be cumulative.nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5364
3357
2471
1310
1018
