September 27, 2017 at 11:19 am
admin
Ansys EmployeeWhat is the difference between interpreted and compiled UDFs?
October 17, 2017 at 6:04 am
admin
Ansys EmployeeThe major difference between interpreted and compiled UDFs is that interpreted UDFs cannot access FLUENT solver data using direct structure references; they can only indirectly access data through the use of Fluent-supplied macros. This can be significant if, for example, you want to introduce new data structures in your UDF. Thus, when deciding which type of UDF to use for your ANSYS Fluent model: •Use interpreted UDFs for small, straightforward functions •Use compiled UDFs for complex functions that: •Have a significant CPU requirement (for example, a property UDF that is called on a per-cell basis every iteration) •Require access to a shared library. For more information on these differences please open ANSYS Help Viewer click on the Go To Page icon and enter the command help/fluudf/fluudf_InterpretedVSCompiled.html in the pop-up window then click on Go.
5426
3391
2471
1310
1022
