November 27, 2019 at 5:51 am
happykiran
SubscriberHi,
Recently I was working with a problem where point mass and gravity are considered. but instead of Gravity, I applied acceleration in the upward direction and the results are same. unable to understand which is correct either gravity or acceleration?
November 27, 2019 at 11:24 am
SubscriberGravity is always 9.8 m/s^2 and you can point it in six directions.
Acceleration can be any number and you can point it in any direction.
If you make Acceleration 9.8 m/s^2 in the +Y direction, that is identical to Gravity in the -Y direction.
November 28, 2019 at 5:01 am
happykiran
SubscriberThank you, Peter, for the clarification. But my question is that y Acceleration should be applied in +Y direction which is the same as -Y direction of Gravity. is there any supporting documents (Or theory which proves).
November 28, 2019 at 3:27 pm
SubscriberYou can build a simple model to demonstrate. Make a cube, use a fixed support on the bottom, add -Y gravity, solve and request the reaction force at the fixed support. Suppress gravity and apply a +Y acceleration of 9.8xxxxx m/s^2 (there are more digits you can see in the Gravity field), solve and look at the reaction force. It will be the same.
It's just a sign convention. If you use FLUENT, the sign convention for acceleration is opposite, you use -Y acceleration of 9.8 m/s^2 to create the effect of gravity.
November 29, 2019 at 5:53 am
happykiran
SubscriberThanks Peter
5386
3375
2471
1310
1022
