Discovery Import
Discovery Import
Difference calculator doesn’t works for facet body
    • miyado
      I tried to output pressure drop for simple facet body, but calculate doesn't output any chart.
      I found difference calculator doesn't works for facet body. On the other hand, ordinarily calculator (not difference calculation) works well.
      It seems to be a bug. Could you investigate it?
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Gaurav Sharma
      Hi Miyado
      I confirmed your observations and it seems there is a limitation on the use of "difference" option of chart on faceted geometries. I am sharing this observation with the developer. Will keep you updated.
      Thanks & Regards,
      Gaurav
    • Gaurav Sharma
      Hi Miyado
      I heard that this is a bug and have filed BUG177081 for the same.
      Thanks for sharing this observation.
      Best Regards,
      Gaurav
