Difference in the magnitude of velocity vector and velocity contour in Fluent
    • MDave
      I performed transient analysis using Eulerian-Granular model in Fluent. I observed the difference in the magnitude of velocity in vectors and contour plots. Please explain the reason behind this.
      Thank you.
      Regards
      M. Dave
    • MDave
      Here is the values displayed in the vector and the contour legends. The maximum value also differs.
      What happens if you plot the contour with node values off?
    • DrAmine
      Global/Local Range----Node Values On / Off.
    • MDave
      I've understood now. Thank you very much.
    • DrAmine
      ­ƒæì­ƒæî
Viewing 5 reply threads
