June 29, 2023 at 2:07 pm
Altair45
SubscriberCurrently, I investigate the transmission, reflection, effective index, and group velocity in Bragg Grating optical waveguide using the FDTD simulation.Before running the simulation, I confirmed the calculated mode and mode profiles in the 'select mode' of Mode Source as the attached image below.After the simulation, I confirmed that the max index in the mode profile, attached second image below, was 6.01. But, the calculated effective index was about 2.5.Accordingly, I think that the index of the mode profile is the group index.I will appreciate your concern to tell the meaning of the difference in the indexes. -
June 29, 2023 at 6:37 pm
Guilin Sun
Ansys EmployeeSomehow the middle figure shows index > 3.4, and the autodetected max index is 3.47175.
”Accordingly, I think that the index of the mode profile is the group index.” The first column is the mode number, and the group index is not shown in your case. Maybe you need to upgrade your software:
Please check the material properties carefully.
If you want to calculate the group index, you may need to check it here:
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7676
4476
2957
1433
1322
