May 28, 2019 at 2:27 pm
AdhityaKrishnan
SubscriberI am facing a problem in initializing different initial temperature for two different objects in ansys transient thermal. Can anyone suggest a method to proceed? Thanks for the help in advance
May 28, 2019 at 6:26 pm
jj77
SubscriberWhat do you mean by different objects - can you add a screen shots of your wb project and details - the more info the easier for us to give feedback.
If you mean how to set different reference temp. for different parts, then under details of the part and definition, set reference temp. option to by body and then type in the ref. temp. for that body, see below:
May 28, 2019 at 8:11 pm
May 29, 2019 at 2:50 pm
AdhityaKrishnan
SubscriberI found the solution to this problem.
Create a named selection of the entity that you want to initialize. BODY1
Create a command in the analysis : IC,NODE,LAB,VALUE,VALUE1,VALUE2,NEND,NINL
NODE: Select the named selection :BODY1
Lab : TEMP
Value: 300
Ex.: IC,BODY1,TEMP,300
Run the program.
- How to move duplicated ansys project position in workbench GUI
- unable to open files in ansys
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Error: Unable to open some designs in this project – Corrupted project files
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- How to export high resolution images in APDL
7592
4440
2953
1427
1322
