May 10, 2021 at 2:51 pm
MikeS
SubscriberHello,
I am running Lumerical 2021 R1.3 on two computers, one Windows (Windows 10 Pro) and one Linux ( CentOS Linux release 7.9.2009 (Core) ). In both cases I am using the varFDTD solver, but the end result is different on each OS.
The *.lms files were created on the windows computer and the file I am running on Linux is a copy of the original.
Has anyone else noticed something similar? Any ideas what to check so the results converge?
Thanks in advance!
May 10, 2021 at 7:59 pmKyle
Can you please give some more information on the simulation, and how the results differ? Remember that Ansys staff can't download files from the ALF (see this post for more information), so please put any screenshots directly into your post instead of attaching the image files.
May 11, 2021 at 9:00 amMikeS
Thanks for the reply.
I am not sure what kind of information would be useful. The parameters of the simulations are identical (geometry, structures, monitors, solver, etc...). The field values recorded by the power monitors are different. Their absolute difference is not important, however the mode profile is. Below are the images of the simulated geometry and the result of the top-view power monitor for Linux (upper images) and Windows (lower images). Since the profiles are different, every calculation I run on them gives different results, so I think they are not needed.
All images are produced with Lumerical's native plotting capabilities on the same computer running Windows 10.
I noticed that when I increase the simulation area towards the +y (upper y bound) in Linux, the results agree much better with the windows' outcome. If a more specific piece of information is required, let me know.
Thanks a lot and cheers!
May 15, 2021 at 12:27 amKyle
Thank you for providing this info. It looks like there is some scattering from the mode source in the Linux simulation that isn't present in the Windows simulation results. I would recommend that you plot the modes used by the mode source in each simulation to make sure that they are the same. It might be a good idea to check the slab mode of the varFDTD solver and the material fits as well before running the simulations again.
May 17, 2021 at 7:55 amMikeS
SubscriberThanks for the feedback,I'll check your suggestions.
May 6, 2022 at 9:52 amfischbac
SubscriberI once had a similar problem. For me it turned out, that the global source settings were not updated by the *.lms file. Maybe you had a similar issue. I know it's been a while :D
Viewing 5 reply threads- The topic ‘Different simulation results on Windows and Linux’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
