August 5, 2019 at 2:34 pm
kedy4ect
SubscriberHi
I am using ansys fluent version 19.1. I have used the same case and data file to run on two different computers. However, I found that there is a slight difference in the solution calculated.
May I know is there a way to standardise the solutions by clearing off residual data, reordering the mesh or etc..
Thanks
Regards -
August 6, 2019 at 3:38 pm
DrAmine
Ansys EmployeeCheck if the cases are deeply converging. -
August 10, 2019 at 3:55 am
kedy4ect
SubscriberHi,
Yes it is converging. But the final solution is different from the two computers. Is there any way to kind of reset all the data before initializing the solution again?
Thanks
August 12, 2019 at 5:05 am
DrAmine
Ansys EmployeeInitialization will reset everything.
Tiggt Convergence has to be reached on bith machines otherwise it dies not make sense to compare.
2614
2092
1321
1108
459
