Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Different type of elements in CFX
    • hgsdvd
      Hello Ansysers,
      I am using both the Mechanical APDL and CFX to model a beam and study it thermally. When I use APDL, there are so many elements that I can choose from such as SURF, TARGET, SHELL, etc.
      My question is where can I find these mesh elements in CFX or shall I use ICEM-CFD to do so. On the other word, does CFX qualify of analyzing this model at the same capability of APDL?
      Best Regards,
      Muha
    • raul.raghav
      Muha, CFX is a fluid dynamics solver. Why do you want to model thermal heat transfer in a beam using a fluid dynamics solver? Could you explain in detail what you're trying to do?
      If you are looking at a 1-way FSI mapping of APDL and CFX, refer to the following:
      FSI with Mechanical APDL and CFX: Manual One-way Mapping
      Unidirectional (One-Way) FSI
    • hgsdvd
      Hello Rahul, I am studying the differences between the two solvers in a thermal wise so I need to match the physical and mesh properties in those solvers. Is there any way where I can do so especially in terms of the mesh elements.
      Thanks
      Muha,
    • raul.raghav
      Could you provide a schematic of your setup and explain which parameters you are interested in comparing? This would help in answering if it could be done with CFX.
      CFX is a finite volume solver and the valid mesh element types are:
      Valid Mesh Elements in CFX
    • hgsdvd
      Thanks Rahul. You answered my question indirectly.
      I appreciate your effort.
      Muha,
Viewing 4 reply threads
  • The topic ‘Different type of elements in CFX’ is closed to new replies.
