3D Design
3D Design
Difficulties in automatizing Faces selection in SpaceClaim
    • pribrands
      Hi all,
      I am trying to automatize the creation of a geometry in SpaceClaim. But I am having difficulting in selecting multiple faces to be extruded, when the nb of faces is a variable. I created a list with the faces names as strings. But I don't know how to convert string to ScriptSmartVariable. Any hints on that are very welcome. I am copying the important part of the script below:
      Thank you in advance,
      Priscilla.
      NbColsZ = 3
      NbColsY = 3
      for itemnb in range(NbColsY*NbColsZ):
          facename='Face'+str(itemnb+1)
          # Create Named Selection Group
          primarySelection = Selection.Create(facename)
    • Keyur Kanade
      please post under geometry and cad category to get better response.
      right now i am moving this thread to the same.
      i am not scripting expert. but why do you need scripting? can you please check if you can make use of parameters in spaceclaim.
      Keyur
