May 23, 2019 at 8:01 am
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi, I noticed that in the last version if a user has set the rotation with the right mouse button (RMB), when he goes to create the table setting he no longer has the possibility of letting the minus out with the right mouse button (to align the dimensions or use other commands).
How can I solve this problem?For now the problem can temporarily be circumvented by changing the rotation command, but I would like to know if there is another way.
You can send me the email in private so I send you the example files (the files we talked about when we connected remotely)
Naresh Patre Subashni
May 23, 2019 at 11:00 am
Naresh Patre
Ansys EmployeeHello Roberto
I checked the right click behavior in the latest version and previous version this appears to be a defect. I have submitted BUG 124721 for this issue. As a workaround, please use other options for Spin (Rotation). I will let you know once this bug gets fixed.
Regarding the other issues, please send files to ansys-discovery-support@ansys.com and we will look into it.
May 23, 2019 at 12:30 pm
rg
SubscriberNaresh Patre Good morning, thank you very much
June 3, 2019 at 12:42 pm
Naresh Patre
BUG 124721(Right click menu not appearing when Spin mode is set as RMB) has been fixed in next version i.e. 2019 R3.
June 3, 2019 at 1:41 pm
rg
SubscriberNaresh Patre Thank you very much, you were very fast
3822
2607
1853
1244
600
