November 28, 2019 at 12:03 pm
garias
SubscriberWe have a user that imports DWG files into SpaceClaim, then they edit it and export it back to DWG format. Normaly this workflow works fine but with some of the drawings they are having problems when they export them back to DWG files, the dimension are not exported and some of the annotations are slightly tilted. I have attachded the imported DWG file in SpaceClaim 2019 R2 (the problems also happens in R3) and the exported DWG file where you can see that no dimensions are exported.
I think the problems comes from the units iterpretaions original dwg file in mm but deteded as inches or something like that but not sure.
Any ideas why is this happening? Also I've noticed that if I exported to PDF format the PDF files comes totally blank
Thanks a lot for you help
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
November 28, 2019 at 12:46 pm
Naresh Patre
Ansys EmployeeHello Gabriel Arias
I will look into it and get back to you.
November 29, 2019 at 12:30 pm
Naresh Patre
I noticed that the view of drawing sheet in scdoc file was not exactly parallel to XY plane. I clicked on the Z axis in the triad (located at the bottom left) to orient the view and made it parallel to XY plane. I now exported it as DWG file and upon opening it, I could see all the dimensions.
November 29, 2019 at 12:49 pm
December 2, 2019 at 7:32 am
Naresh Patre
I have submitted bug 213255 for this issue and will let you know as soon as I hear from the development team.
December 2, 2019 at 9:16 am
garias
SubscriberThanks a lot Naresh
June 25, 2020 at 11:59 am
3720
2570
1783
1236
594
