Discovery Import
Discovery Import
Dimensions on 3D pipes
    • mu
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      is there a way to select the lines indicated in below images when I insert a dimension in drawing?
      Thank you in advance,
      Best regards,
      Marco
    • Subashni Ravichandran
      Hello Marco Ugolotti
      Here the workaround would be to make a Construction line and create a dimension using that.
      Please check the attached file with the dimension marked.
      • mu
        Thank you Subashni ,
        actually for now we are using a similar workaround (we are creating a point), but the problem of this workaround is that changing the pipe the dimension is not correctly updated.
        Is there any chance to be able to select the model line?
        Regads,
        Marco
      • rg
        Subashni Hello
        yes this is a solution but it is inconvenient to do it for many quotas, it can be a temporary solution and not forever, and the problem is that if you update the size of the pipe the dimension does not update
        Regards
      Hello Marco Ugolotti Roberto
      I understand this may be inconvenient. Please post in the Ideas Section so that our development team can look into this.
      • rg
        Subashni Hello
        We hope that the developers solve the problem, thank you I will write it in the ideas
        Regards
