Diode properties cannot be updated in Ansys Circuit
    • smykng
      I'd like to change diode parameter (e.g. PB, contact potential) and simulate circuit. However, even after updating parameter and checking override check box, waveform has not been changed. (Of course I pressed apply button and ran Analyze again.)
      I used official example circuit below.
      File => Open Examples => Examples/Circuit/RF Microwave/Mixers/SimpleMixer
      Please help me if you know how to apply property update.
    • Praneeth
      Did you go through the associated document "Getting Started with Circuit Design: Transmission Line, Mixer, and Channel"?
      Can you try running a parametric and compare the results?
      All the very best.
    • smykng
      Thank you so much for your answer. I didn't read "Getting Started with Circuit Design" yet.
      I would like to read it to learn how to use this software.
      Could you please tell me where I can get this Document ?
    • Praneeth
      You can access the getting started guide from the help tab of the AEDT interface.
      All the very best.
Viewing 3 reply threads
