May 13, 2022 at 9:11 am
manelaero2020
SubscriberHi friends ;
I will model the following simulation in fluent :
we have a humid upstream flow ( air + vapor of water ) that will pass through a water separator filter
the objective is to determine the efficacity of the water separator, thus determining which amount of water droplets are captured in the filter
Which model should I use in fluent? (DPM or diphasic model? ) if diphasic model, wich one please ? )
I am very thankful
Best regards
May 13, 2022 at 10:11 amRob
Forum ModeratorNot as easy as it sounds. Vapour is a gas so won't get picked up by most filters. Assuming a low droplet volume fraction, DPM is the best option. However, you then need to figure out the filter: do you want to trap a percentage, anything over a certain size etc? Unless you model every fibre/filament/plate in the filter we can't tell you the separation efficiency. What we would use CFD for is to figure out what gets to the filter, where it arrives and how quickly.
May 13, 2022 at 11:50 ammanelaero2020
SubscriberHi I want to see basicaly how water behaves inside the filter
So , do you think Wet steam model is most suitable than DPM MODEL?
THANK YOU
May 13, 2022 at 12:27 pmRob
Forum ModeratorNo. Water vapour or water droplets? If you want to capture what's going on inside the filter you'll need to create the fibre/foam/whatever geometry: good luck. There's a reason everyone uses porous media....
May 13, 2022 at 1:28 pmmanelaero2020
SubscriberWater vapor will condensate inside the filter , that is the problem that i modelize , What do you think ? Which model ? Wet steam ? I think DPM is more suitable for water droplets
I am sorry if i wasn't clear
May 13, 2022 at 2:25 pmRob
Forum ModeratorCondensation onto micro fibres? I'd be looking at wall film, and maybe Eulerian for the phase change and a species model for the air+vapour mixture. But, big but, how do you plan on building the filter geometry?
May 13, 2022 at 3:23 pmmanelaero2020
SubscriberThank you , a geometry such like cyclonic filtration
Filtration by a wirling flow , may be
May 13, 2022 at 3:27 pmmanelaero2020
I am not sure that cyclonic filtration works for water vapor , i will try to see that
May 13, 2022 at 4:10 pmRob
Forum ModeratorNot really, to strip out a vapour you need to cool it.
Viewing 8 reply threads- The topic ‘diphasic or DPM model ?’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
