February 27, 2023 at 1:44 pm
XINGLONG WU
SubscriberDear all,
I noticed that if we put the dipole (Hertzian-dipole excitation) close to the ground and I measured the E-field at one point far from the dipole, the simulated E-field is different from the one I obtained by using image method.
Specifically, I did the following HFSS simulations and I noticed some differences
Working frequency: 200 MHz. E-field observation point P1: (0, 0, 400) mm
Working space: free-space with a XY perfect conductor (PEC) plane at z = 0 mm.
HFSS case #1: One dipole in a free-space space with a XY perfect conductor (PEC) plane at z = 0 mm.
Dipole information: +y E Hertzian dipole, L=50 mm, Radius: 5 mm, location (0, 0, 30) mm (30 mm above the PEC plane.
HFSS case #2 (image method): Two dipoles in a free-space space.
Dipole information :
1. +y E Hertzian dipole, L=50 mm, Radius: 5 mm, location (0, 0, 30) mm.
2. -y E Hertzian dipole, L=50 mm, Radius: 5 mm, location (0, 0, -30) mm
It is observed that the total E-field at P1 generated in case #1 and #2 are difference.
My questions is:
1. Why the differences are observed in Case #1 and Case #2 when the same setting is considered (same working space, same setting for analysis, etc.)
March 2, 2023 at 1:43 pm
Praneeth
Ansys EmployeeHi Xinglong,
Thank you for reaching out to us.
Please see my observations / comments from your post:
- Did you check "infinte ground plane" while setting the PEC boundary condition in Case-1?
- Did you excite both the antennas for case-2? Please share the edit sources dialog box for case-2 simulation.
Please share screenshots of the simulation geometry and setup to help us serve you better.
Best regards,
Praneeth. -
March 5, 2023 at 9:48 pm
XINGLONG WU
SubscriberHi! Praneeth,
Regarding the simulation geometry and setup, The setings for the two cases are similar.
The solving space Box1 size: Position: (-500, -500, 0); (Xsize, Ysize, Zsize) = (1000, 1000, 600). It is larger than the suggested size: Lambda/4.
Solution types: HFSS-Network Analysis-Terminal (ANSYS 2022 R2)
Analysis Setup: Freq = 4 GHz, Maximum number of passes: 20, Maximum Delta Energy: 0.1. Others: Default. Sweep: discrete-single point at 200 MHz.
A screenshot:
It is also noticed that the sizes of the solving space can affect the result of case 1, but cannot affect the result of case 2. The result of case 2 is constant and is always equal to the one obtained from the theoritical calculations. Therefore, I guess the difference is due to the pec GND of case 1. But I don't know the reason.
I hope the information is enough and I look forward to your feedback/suggestions.
Thanks and best regards,
Xinglong
- Maxwell, HFSS or Q3D?
- Error
3862
2639
1859
1254
600
