April 2, 2023 at 3:52 pm
GUICAD
SubscriberHello,
Could you explain me why the direction of the moment is not symmetrically oriented as in the green part ?
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
April 3, 2023 at 2:16 am
Devendra Badgujar
Forum ModeratorHello GUICAD
It looks like you are creating an origin for the selected objects. You can insert an origin at any location in your design where you can anchor the Move tool. You can also insert an origin at a solid's center of mass or volume.
The direction of the moment is not symmetrically oriented as in the green part, because it has created the coordinate system at the center of the selected object. You can use Move tool to anchor your coordinate system as shown in the attached video.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
