July 12, 2019 at 9:07 am
Smitha
SubscriberI need to assign direction of magnetization to some permanent magnets, part of a 3D model in Ansys Maxwell. In order to do that, I need to create relative frames of references with respect to each of the magnets. How do I do that in a 3d model using cylindrical coordinate system? Please specify steps, preferably with an example. Thank you.
August 16, 2019 at 6:58 pm
Paul Larsen
Ansys EmployeeEvery coordinate system in Maxwell acts simultaneously as Cartesian, Cylindrical, Spherical. You just need align it along the Z-axis, and set the material properties as Cylindrical. In the upper-right of the Material property definition, change Cartesian to Cylindrical, and you will see the Magnetic Coercivity vector expressed as R, Theta, Z. Then, make sure that your object is assigned with the correct material, and use the Orientation property on your object to choose the correct coordinate system.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
594
