3D Design
3D Design
Directional properties
    • sunny.sihag96
      I am working on a wind turbine and need some help in implementing the structural properties as in the experiment the properties and mass are given as per distance. Since there is no thickness information given I have made my model as a surface body so that the properties and thickness can be applied.
      I need guidance.
      Thanks in advance
    • Rahul Kumbhar
      could you please elaborate more on what issue do you need help?
    • sunny.sihag96
      Actually, i am modelling a wind turbine in static structural and the properties of material are not given as it is in the experiment instead the blade properties are given in this way. and I am unable to make the wind turbine with this data. and I have made a surfacemodel and I don't have information on thickness of the blade too.
