Discovery Import
Discovery Import
Discovery Aim – Hyperthreading error question
    • tim.dukes
      Hi Support,   Discovery Aim doesn't support hyperthreading I believe as you get the error in the page below- https://discoveryforum.ansys.com/t/q5r3bl/discovery-aim-resolving-hwloc-topology-error   Is this different to workbench and Fluent? Dell optimiser turns on hyperthreading automatically to improve performance see image below (CPU Optimizations) A customer disabled hyperthreading due to the error in the thread link above but then got this error in the image below.  Any ideas what this is referring to or what this means?
    • Brian Bueno
      Tim Dukes
      I'll check with the AIM team to see if they've encountered this one before.
    • tim.dukes
      Brian Bueno
      Deleting the temp files got rid of the error messages.
      Do you know if hyperthreading is recommended in Fluent/Workbench or if this is just the Dell optimiser guessing at best settings?
