Discovery Import
Discovery Import
Discovery AIM Mesh Error
    • tim.dukes
      Hi Support,
      Do you know why the error in the image below would occur. Updated Mesh failed.
      Jacobian of the mesh is positive- usual this is the  biggest issue.
    • Subashni Ravichandran
      Hello Tim Dukes
      I have not seen this error before. Let me check with my team on this error. Are you using manual mesh or automatic meshing?
      If you are using manual mesh, could you try reducing the growth rate?
    • BhaskarModak
      I'm having the same error. Please confirm the solution.
      • Naresh Patre
        Bhaskar Since you have already submitted a separate question for the meshing issue, I would request to continue your discussion through that question.
    • BhaskarModak
      Okay. Thanks.
Viewing 3 reply threads
