June 18, 2019 at 8:42 am
raymond408
SubscriberI have a client who uninstall the ANSYS Discovery Ultimate 19.2 and install the ANSYS Discovery Ultimate 2019 R1 (Subscription). After installation, no input box was prompted, therefore, using command to deactivate the previous license. Afterward, the input box was prompted and pass checking. But AIM still not starting, do you know how to resolve this problem?
June 18, 2019 at 9:29 am
Naresh Patre
Ansys EmployeeHello Raymond Chiu
Can Discovery LIVE and SpaceClaim be launched without any issue?
I could find a similar problem reported on Discovery forum and it was resolved by disabling onboard display card. Below is the link to this forum question. Can you try it and let me know if it helps?
June 18, 2019 at 1:45 pm
raymond408
June 19, 2019 at 7:47 am
Naresh Patre
Ansys EmployeeHello Raymond408
Does the customer has any non-English characters in the username? We have seen where any non-English characters can cause problems. If yes, can the user create another user login with a name not containing non-English characters to see if they encounter the same problems?
June 19, 2019 at 2:17 pm
raymond408
SubscriberDear Naresh Patre
No non-English charters in the user name. I test the machine in client's office today. Below is the summary, and I have prepared a detail summary in attached pdf. Please take a look.
Launch AIM
SolidEdge Configuration
ANSYS Discovery AIM – 19.2
OK
Not OK
ANSYS Discovery AIM – 2019 R1
Not OK
OK
ANSYS Discovery AIM – 2019 R2
Not OK
OK
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
June 20, 2019 at 4:54 am
Naresh Patre
Were the prerequisites installed properly? You can try installing each one separately from within the installer path mentioned below.
DISCOVERY_ULTIMATE_2019R2_WINX64prereq
After installing the prerequisites, restart your machine and try launching Discovery AIM. If the problem persists, please generate log files as per the steps listed below and send them to ansys-discovery-support@ansys.com
- Open "Event Viewer" by clicking the "Start" button
- Click "Control Panel" > "System and Security" > "Administrative Tools", and then double-click "Event Viewer"
- Click to expand "Windows Logs" in the left pane, and then select "Application".
- Click the "Action" menu and select "Save All Events As".
- Name the file "Applicationviewer.evtx" and click the "Save" button.
- Click the "OK" button if you see a "Display Information" dialog.
- Repeat Steps 3-5 and select "System" and save as "Systemviewer.evtx"
- You're done! Please send the 2 files to ansys-discovery-support@ansys.com.
June 20, 2019 at 7:21 am
June 20, 2019 at 8:52 am
Naresh Patre
Ansys EmployeeHello ASMCAE1
Please install all the listed items in the folder.
3812
2593
1849
1244
600
