July 12, 2019 at 11:07 am
July 12, 2019 at 11:37 am
Gaurav Sharma
SubscriberHi RD
I need to have a better look at the model to understand what might be going wrong. I have shared a securetransfer link on your email, that you can use to upload your model.
Thanks & Regards,
Gaurav
July 12, 2019 at 11:47 am
rohandixit1987
Subscriber-
July 12, 2019 at 12:06 pm
Gaurav Sharma
SubscriberRD
As per the attached transcript image, it seems you do not have enough memory available to solve this problem. You can try with a coarser mesh and ensure the node count is reduced, and that should help to attain a solution.
By the way, the transcript image also shows that there was a warning message encountered. Can you also share screenshot of the warning message.
Thanks & Regards,
Gaurav
July 15, 2019 at 3:06 am
July 15, 2019 at 6:32 am
Gaurav Sharma
SubscriberRD
It seems you are using an element shape input to your mesh and the shape is set to "Hexahedrons". If your geometry is complex and difficult to be captured by hexahedrons only, this will lead to failure of mesh and the error in your case appears to be indicating towards this.
If there are no specific reasons for the need of all hex mesh, you may try by using shape = automatic and this should do away the problem.
Gaurav
July 12, 2019 at 3:42 pm
rohandixit1987
SubscriberGaurav_ANSYS
Kindly find attached warning message.
Please can you suggest some mesh parameters so that I can get a solution.
RD
July 15, 2019 at 6:28 am
Gaurav Sharma
SubscriberRD
Thanks for sharing the snapshot. This is a generic information and can safely be ignored.
July 15, 2019 at 11:27 am
rohandixit1987
Subscriber -
July 16, 2019 at 6:24 am
Gaurav Sharma
SubscriberRD
Did you try the options listed under repair tab. They should be helpful.
To know more about different options, you can place the cursor on any icon and hit F1 to open the detailed help. The "extra edges" highlighted above should help you do away some of the problems you have highlighted.
Gaurav
July 16, 2019 at 8:30 am
rohandixit1987
Thank you for the reply. I tried out these options and was able to solve the geometry errors.
Query - ANSYS AIM is frequently Not Responding and closing down. Please can you suggest something in order to avoid this and speed up the process.
RD
July 16, 2019 at 8:41 am
Gaurav Sharma
SubscriberRD
Such issues with AIM are generally resolved by following the options listed below:
1. Clear the contents of temp folder (type %temp% in windows Taskbar to access temp folder)
2. Close all the open Discovery Applications and go to the following appdata folder (C:Users****AppDataRoamingAnsys) and rename the folder v194 to v194.old)
3. Try updating the your graphics driver by visiting http://www.nvidia.com/Download/index.aspx.
PS: I would encourage you to use "Request Support" everytime there is a new query, which is not related to the ongoing discussion. This helps in better management of queries and is also easier for other users to search for it and benefit out of it in case they are facing similar issues. Thanks for your understanding.
Best Regards,
Gaurav
July 16, 2019 at 9:20 am
rohandixit1987
Henceforth, I will use Request Support for every new query.
RD
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3720
2566
1771
1236
594
