Discovery Import
Discovery Import
discovery can not open,licensing Error
    • zhihong.song
      license  entiltements have not been refresher,can not log in to the account?
    • Naresh Patre
      Hello Zhihong Song
      The error message indicates that you need to refresh your subscription license. The command for refreshing license is mentioned in the article "Discovery Subscription license - Command line options". For your reference, below are the steps and the required command to be executed
      Please find below the steps to execute the command:
      1.    Launch the Windows Command Prompt from the start menu in administrative mode.
      2.    In the command prompt, type in:
      cd C:Program FilesANSYS IncShared FilesLicensingwinx64
      (this is the default installation directory of Discovery products. If you have installed it at a different location, enter the appropriate path where ansysls_client.exe is present)
      3.    Once in that directory, run the following command:
      ansysls_client.exe -RefreshLicenseEntitlements
      This command refreshes license subscriptions on that machine. If Discovery products are not launched for more than a month, execute this command to refresh the license.
