July 13, 2018 at 9:45 am
roland.ruf
SubscriberHi all, while updating Ansys Workbench from 19.0 to 19.1 we reinstalled discovery live (which worked before updating). Now using Ansys 19.1, Discovery doesn't start anymore after reinstalling. We get an error message concerning the initializing of CUDA. We do have the latest graphic-card driver. So now the question: What is wrong? What can we do? Thanks for response.
July 13, 2018 at 10:17 am
July 13, 2018 at 11:11 am
roland.ruf
SubscriberHallo Naresh Patre ,
thank you for your quick response. We installed the latest CUDA toolkit as you aviced. But it did not fix the problem. Still the same error message occurs.
July 13, 2018 at 11:32 am
Naresh Patre
Ansys EmployeeHello Roland Go into the NVIDIA Control Panel (i.e. right click on your PC desktop, or through Windows search option). Then go to "Manage 3D settings" There will be 2 tabs, "Global settings" and "Program settings" Go to "Program settings", select "SpaceClaim" and then set "Preferred Graphics processor" as "High Controlled NVIDIA processor" and "Power Management Mode" as NVIDIA driver-controlled"If the above options are not helping, send the following log files located in %AppData%RoamingSpaceClaimLog Files after this CUDA message occurs: SpaceClaim_*.log RHApplication_*.log RHSolver_*.log
July 16, 2018 at 11:02 am
roland.ruf
SubscriberHello Naresh Patre
I took over your adaptations for the setting of the graphic-card. But I did not work.
Beside that, I don't have all the options as mentioned by you. Just have a look at the attached screen shot.
Furthermore I attached the log file, as you asked.
So what else can we do in order to run Discovery Live?
July 16, 2018 at 1:20 pm
Naresh Patre
Ansys EmployeeRoland Can you check if you also have files starting with RHApplication_ and RHSolver_ in the logs folder? Can you upload them as well?
July 16, 2018 at 2:03 pm
roland.ruf
I have an RHApplication file in that folder. Attached you can find that file.
I don't have an RHSolver file.
July 17, 2018 at 8:45 am
Naresh Patre
Ansys EmployeeRoland Thank you for sharing the files. I have passed it to development for investigation and will let you know.
August 1, 2018 at 12:50 pm
roland.ruf
SubscriberWe uninstall and reinstall discovery. Now it works...
We don't know what the problem was. But now it works...
Regards
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
3744
2573
1821
1236
594
