February 8, 2023 at 4:32 am
Pedro Álvarez
SubscriberWhen I start up ansys discovery and try to import a STEP design,the program does not show the design and the following error appears on the bottom of the screen:
-Explore is not available due to an incompatible graphics device or an out of date graphics driver. Update....
-A translation report is available at ... -
February 8, 2023 at 5:28 am
Subashni Ravichandran
Forum ModeratorHello Pedro Álvarez
Discovery Explore mode requires a 8Gb graphics card for best performance.
Please check the minimum hardware requirements here.
Ansys Discovery Hardware Requirements - Knowledge Base - Ansys Discovery Forum
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8808
4658
3151
1680
1470
