February 20, 2020 at 10:34 am
tim.dukes
SubscriberHi Support ,
A customer is currently struggling to update to 2020R1.
When installing they get an error which doesn't say anything see below.
Things we have tried. Re-downloading the software in case of a faulty download. Un-installing everything first.
Completely removing /un-installing all ANSYS from the machine C drive and also Temp files before trying a fresh install. C:UsersYour pc nameAppDataLocalTemp.ansys
Install is always ran as ADMIN.
After the installation fails the only install log that appears is the one I attach.
There IT has looked into it and there are no firewalls or proxy that would block this.
They can install 2019R3 without any issue.
I have attached there now TEMP files but these look like they are all relevant to V195 version they installed.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
February 21, 2020 at 8:36 am
Subashni Ravichandran
Ansys EmployeeHello Tim Dukes
As I have not seen an error like this before and I do not see any information in the log file as well. I will discuss this with the team and keep you updated.
February 26, 2020 at 4:59 am
Sorry for the delayed response. This issue has been reported by another user and our team is looking into it.
I will keep you updated as I hear from them.
February 26, 2020 at 5:25 am
While I discuss this issue with the team, could you please delete the following and try again
%APPDATA%Ansysv201
%APPDATA%SpaceClaim
C:UsersUSERNAMEAppDataLocalSpaceClaim
If that does not work, could you please send us a copy of the Windows Event Logs from Windows Event Viewer? Specifically, the System and Application logs.
To access Event Viewer please follow the below steps:
Open Control Panel > System Security>Administrative Tools> Event Viewer
Under Windows Logs > Application (or System). Select the logs and right-click to save selected events.
Once the files are saved zip the files and share it to ansys-discovery-support@ansys.com -
February 27, 2020 at 10:26 am
tim.dukes
SubscriberHi Subashni
Will send to the user and send the files through.
Tim
March 3, 2020 at 10:24 am
Any updates on this?
March 4, 2020 at 2:20 pm
tim.dukes
Customer has deleted and tried again with the same results.
I have sent the logs through to ansys-discovery-support@ansys.com
Tim
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3702
2564
1765
1236
592
