April 15, 2021 at 6:27 am
smjang
SubscriberHi,
I have a question while making discovery related materials.
Fidelity at the Explore stage was compared for each graphic card using a PC owned by the company.
Although the graphics card type is different, it has been confirmed that the Fidelity value is the same when the GPU-only memory is the same.
So, whether I need RTX graphics or Quadro graphics, I wonder if the Fidelity values are the same if the memory values are the same.
And when suggesting a graphics card to a customer, ask if you can recommend the largest GPU memory.Another thing I'm curious about is that the last specification is that the graphics card has three. However, the difference in performance does not seem to be much greater than that of having one graphic card.
Please inquire if the presence or absence of the number of graphics cards affects the Fidelity value in the Explore phase.Thank you.
April 15, 2021 at 9:25 am
Subashni Ravichandran
Ansys EmployeeHello smjang
Thank you for reporting these observations.
Let me check this with the developers and get back to you
May 7, 2021 at 10:46 am
I apologize for the late response here.
I discussed this with my team and there are a couple of things here:
Irrespective of the type of Graphics card, for the same GPU memory the fidelity will more or less be very similar.
In the last case with 3 Graphics cards, Discovery will only use one graphics card at a time. Therefore using multiple graphics will not really make any difference.
May 10, 2021 at 11:02 pm
smjang
SubscriberSubashni Thank you for the quick answer. We will use it well for customer training and additional applications. Thank you.
May 26, 2021 at 8:11 am
rg
SubscriberHello smjang Is the simulation calculation faster with the geforce rtx 2060 or with the quadro rtx?
Subashni
Best Regards
May 26, 2021 at 11:36 pm
smjang
SubscriberRoberto It is impossible to compare the fast ones as the simulation proceeds with a simple shape. I'm not sure that the Explore step comes out in seconds. We could only compare the Fidelity which is determined by the amount of GPU memory.
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
3744
2573
1821
1236
594
