October 15, 2018 at 1:36 pm
October 15, 2018 at 2:29 pm
tim.dukes
SubscriberHave just seen this which is what customer is seeing when checking the connection so will try these steps.
6) For ping command showing 0% loss:
If ping command output is showing 0% loss and still you are unable to launch Discovery product, then perform following steps:
1. Send output of ping command to Discovery Support Team
2. Download attachment "curl_7_53_1.zip" from below link and extract Download Curl Installer
3. Rename curl.exe.tmp to curl.exe
4. Open Command prompt in administrative mode and go to the location where curl.exe is saved
5. Execute following command:
curl.exe -v https://ansys-fno.flexnetoperations.com
6. Send the output of above command to Discovery Support Team
7. Type %temp% in Windows Search and go inside .ansys folder. Locate .log file starting with ansysls_client* and send it toDiscovery Support Team
8. Send following log files located at ~
/Ansys Inc Install.log
Install_licconfig.log
Install.err (if it exists)
October 15, 2018 at 8:53 pm
Brian Bueno
Ansys EmployeeTim Dukes
Based on the images in the email received from the customer, my initial guess is that they are running an older version of Discovery that does not support an enterprise floating license. I have advised the user to download and install Discovery 19.2.
January 8, 2019 at 10:47 am
l.janicek
SubscriberHi, could you tell me, what is the solution of this problem, please?
Our customer has the same problem. He has subscription and Discovery 19.2.
The error is: Curl Error (35) SSL connect error
Ping to ansys-fno.flexnetoperations.com is OK.
Thank you, Lukas
January 8, 2019 at 12:30 pm
tim.dukes
SubscriberHi Lukas
I think our customer did a manual activation in this instance. We have had other customers with Curl error and this was due to proxy server issues so following this may be worth a try. https://discoveryforum.ansys.com/t/m2jxqa/discovery-patch-for-addressing-proxy-server-issues
Tim
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3778
2579
1825
1242
598
