July 8, 2020 at 2:30 pm
papp
SubscriberHi,
I have two questions concerning the newest release of Discovery Live:
- In this presentation slides 5-6 state "Extensible & scriptable application framework". Does this apply to the boundary conditions and output charts as well? In other words, is it possible to set the boundary conditions while the simulation is running, based on model results automatically?
- Is the memory management error resolved?
Thanks,
Bálint
July 9, 2020 at 6:33 am
Naresh Patre
Ansys EmployeeHello Bálint Papp
I am looking into your questions and will get back to you soon.
July 13, 2020 at 11:54 am
papp
SubscriberHi Naresh Patre
Have you found anything on this topic so far?
July 14, 2020 at 2:36 am
Naresh Patre
The Whats New presentation had some slides from development and planning stage. The presentation with the release data is now updated and is at the same link. Thank you for bringing it to our notice and apologies for the misunderstanding and inconvenience.
Regarding memory management, the development team is still working in this direction. And with the launch of new Discovery product, all these development will be happening in future releases of this new product.
July 14, 2020 at 7:35 am
papp
SubscriberNaresh Patre Thanks for your answer.
Do you have any info, whether Live is going to be available as a separate software in future releases? I'm mostly interested if I have to familiarize myself with the new environment, or I'll be able to can use it like so far?
July 14, 2020 at 12:24 pm
Naresh Patre
Version 2020 R2 is the last release of Discovery Live and there won't be any further release. All the development will be happening in the new Discovery application. I would recommend getting familiar with the new tool since that will be the single application going ahead.
July 14, 2020 at 3:47 pm
papp
Subscriber-
July 15, 2020 at 7:14 am
Naresh Patre
Ansys EmployeeBálint Papp
The Turbulence model that you see under "Specify calculation type" are applicable only in Analyze mode and not in Explore mode. The Explore mode still uses LES turbulence model. In fact the turbulence model option for Analyze mode is not exposed in the UI. All the options under "Simulation Options are only applicable for Analyze mode.
July 15, 2020 at 7:31 am
papp
SubscriberThank you Naresh Patre for your detailed answer.
September 10, 2020 at 2:59 pm
papp
SubscriberNaresh Patre Is there any info about whether the memory management problem is solved in release 2020R2.5?
September 15, 2020 at 9:51 am
Naresh Patre
Ansys EmployeeBálint Papp Although there is no fixed timeline, I hope there will be improvements in the feature capturing and (eventually better memory management) in the releases scheduled for next year.
3930
2649
1865
1272
610
