August 6, 2019 at 10:40 am
August 6, 2019 at 10:54 am
Subashni Ravichandran
Ansys Employee-
August 6, 2019 at 11:26 am
rg
SubscriberSubashni Hi
Can I also export a chart with all the values in the legend?
Regards
August 7, 2019 at 7:28 am
Ansys EmployeeHello Roberto
I'm sorry but I don't understand your query clearly. I don't see the purpose of exporting the legend values.
If you would like to export the values of vonMises stresses or deformation at different locations of the geometry, you could create a calculator using 'Value along path' feature and export the chart generated.
Please check the image below. Here, I have created a line along the length of the bracket and generated a chart to show stresses along the line.
Using this chart I have exported the values to a .csv file.
Does this solve your purpose? Or is there any other application you would like to explore?
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
August 7, 2019 at 7:36 am
rg
SubscriberSubashni Hi, this was what I needed.
Thank you very much
3744
2570
1787
1236
594
