February 2, 2021 at 8:17 am
kawabata
SubscriberOur customer has a problem about license activation.
When he launches Discovery Live (2020R2), Discovery Live does not launch. I do not receive any screen capture, but following error message exists in "ansysls_client.***.log" file.
Curl Error (35) SSL connect error - schannel: next InitializeSecurityContext failed: Unknown error (0x80092012) -He has another machine, Discovery Live in the machine works fine.
(He says) He sets environment variable: HTTPS_PROXY, antivirus, firewalls and connections between seven sites.
I asked him installation of CA Certificates because "Curl Error (60) Peer certificate cannot be authenticated with given CA certificates" was in the log file.What should he do/check in next? Would you let me know?
I have received ".ansys" folder from him. So, I can send it to you.Thanks in advance,
Ichiro -
February 2, 2021 at 9:23 am
Naresh Patre
Ansys EmployeeHello Ichiro
I haven't seen this type of curl error before, so not sure what could be the reason and how to overcome it. Please make all the firewall and proxy server changes and mentioned in section 5 of below mentioned trouble shooting document. If the issue persists, please send all the files as listed in section 6 of the same document.
Discovery License Activation Troubleshooting - Knowledge Base - Ansys Discovery Forum
February 2, 2021 at 9:47 am
kawabata
SubscriberHi Naresh Patre , Thank you for reply. < Discovery – No Subscriptions Available – Ansys Learning Forum ; is similar problem, I think. I will send the files to your mentioned address after I received the files from the customer. Thanks, Ichiro
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
5242
3297
2469
