May 13, 2019 at 6:58 pm
May 13, 2019 at 8:55 pm
Brian Bueno
Ansys EmployeeKrishna
Does your PC meet the minimum hardware requirements for Discovery Live?
https://ansyskm.ansys.com/forums/topic/ansys-discovery-hardware-requirements-2022-r2/
Did you install the software using Run as Administrator in Windows?
These are a couple of the most common causes for Discovery Live not working. Do any of the other example models on the Start Page produce results?
May 13, 2019 at 10:16 pm
krishna.mellachervu
SubscriberBrian Bueno My system does support the minimum requirements but I don't remember if I installed using "Run as administrator". I may have to uninstall and reinstall
May 13, 2019 at 11:25 pm
May 15, 2019 at 5:26 pm
krishna.mellachervu
SubscriberAny more suggestions?Please let me know Brian Bueno
May 16, 2019 at 9:07 pm
Brian Bueno
In the NVIDIA Control Panel, make sure your global settings are set to use the high performance NVIDIA processor instead of allowing the application to decide.
This problem is almost certainly something related to either the installation or the graphics hardware or settings.
May 16, 2019 at 10:19 pm
3930
2649
1865
1272
610
