July 25, 2019 at 8:14 am
tim.dukes
SubscriberHi Support a customer wanted clarification on results in Discovery Live. If you run a simulation and hit the pause button for instance at 1 second like in image below and then save it.If you close and re-open the simulation all the results and calculations at that 1 second point are now gone and you have to replay the simulation to get them back. Should these results be saved for later usage or is it that in LIVE because you get results almost instantaneously you feel it isn't necessary to save this data?
July 25, 2019 at 8:43 am
Naresh Patre
Ansys EmployeeHello Tim Dukes
Yes, since Discovery Live gives instantaneous results, the project file doesn't save any results data.
3862
2639
1859
1254
600
