June 12, 2018 at 2:29 pm
philipvdm
SubscriberI have noticed that when I run a simulation in Live and want to import it to Aim, there is an error with all my material properties where it replaces commas with semicolons. Aim does not accept semicolons and i have to manually restore it. Are other users experiencing the same problem or similar? how can we fix this?
June 12, 2018 at 5:45 pm
Brian Bueno
Ansys EmployeePhil12345
I have not been able to reproduce this issue when using version 19.1 of Discovery Live and Discovery AIM.
If you are also using Discovery 19.1, please submit a generic example model that shows the problem.
June 13, 2018 at 8:49 am
philipvdm
SubscriberBBueno_ANSYS I open discovery live, import geometry, Start flow simulation, define boundaries and see the result. Then in the workbench tab i select Discovery AIM (with physics). it transfers the project to AIM but the material assignment does not work. Please see attached project. i also added a picture of the Semicolon error it produces.🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
June 18, 2018 at 2:43 pm
philipvdm
SubscriberBBueno_ANSYSÂ , Have you had a change to inspect this?
June 20, 2018 at 1:35 pm
Brian Bueno
Ansys EmployeePhil12345Â
It looks like this is a defect and will have to be addressed by the development team.
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
- Unexpected graphics error
5346
3345
2471
1310
1018
