April 22, 2021 at 6:11 am
smjang
SubscriberHi,
I have a question about the parameter function of Discovery.
In order to see the temperature change according to the length,'Update all' was executed by designating a parameter.
It was possible to check the change in Max Temperature according to the change in the length specified by the variable.
However, the geometry after the update is completed is changed to the length of the final parameter value. Can't the geometry change at the same time when each parameter is selected?
There is no change even when running after selecting 'Update current'.And is the variable in Discovery recognized as the same variable in Optislang and Mechanical?
Please check this part.
Thank you.
April 22, 2021 at 7:49 am
Naresh Patre
Ansys EmployeeHello smjang
I could see the geometry getting updated for each parameter value. The final geometry and the results that you see correspond to the last parameter value in the parameter table.
I also tried selecting an intermediate parameter, set it as current and updated it. This updated the geometry as per the parameter value and displayed the results.
I think if the changes in the length is very small, then it might be difficult to easily notice the change in geometry. Can you try with higher length values?
Since this parameter is same as any other SpaceClaim parameter, I think it will get recognized in Optislang and Mechanical.
April 22, 2021 at 7:57 am
April 22, 2021 at 9:22 am
Naresh Patre
Ansys Employee-
April 25, 2021 at 11:25 pm
smjang
SubscriberNaresh Patre thank you for your answer. It was a simple one. Thank you.
3930
2649
1865
1272
610
