Discovery Import
Discovery Import
Discovery SpaceClaim – Graphics issue
    • tim.dukes
      Hi Support,
      Have you ever seen SpaceClaim graphics act like the images attached?
      The rendering on screen seems to be fine but the options and the bottom blue bar seem to go a bit strange when hovering over them.
      Things we have tried are deleting temp files, changing the renderer (OPEN GL and directx) also we have updated graphics driver direct from nvidia website.
      Nvidia Geforce RTX 2080 is the graphics card.
      Any ideas what could be causing this.
      Customer reports only happening in SpaceClaim and no other applications.
    • Brian Bueno
      Tim Dukes
      I have seen this once relatively recently.  Is there anything different about the customer's display settings?  Are they scaling text up in the OS or anything similar?
    • chris.dukes
      Hi Brian,  have checked the customers  display settings and everything is normal.  The customer is using a ASUS  ROG G703 LAPTOP with i9-8950 processor, NVidia GEForce RTX 2080 graphics and NVidia Ultrafast 144MHz G-synch display  and Win 10 pro,
      Problem still persists if I shut SC down, and then via the NVidia Control panel set SpaceClaim to use the intel integrated graphics  processor.
      Anything else you can suggest?
      • Brian Bueno
        Chris Dukes
        I'll have to consult with the development team about this.
        Please have the customer run dxdiag.exe from the Windows Start menu, save the output, and send you the file.
    • tim.dukes
      Brian Bueno
      Please see attached the dxdiag information as requested.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      • Brian Bueno
        Tim Dukes
        I've made the development team aware of this.  Seems like it may be a defect, but I'll keep you posted.
Viewing 3 reply threads
