Discovery Import
Discovery Import
Discovery Streamline
    • smjang
      While using a Discovery product, post a post with a part that you'd like to add from time to time.
      If you view the flow area analysis results in Streamline, you will set the beginning of the flow rate using the circle of the attached photo.
      However, if the beginning is two holes instead of one, I would like to be able to set two beginnings in The Streamline.
      In the previous Live, I was able to copy the beginning circle while holding down the cTRL key.
      We'll see if the feature can also be implemented by Discovery.
      And spaceClaim is included in the Discvoery product family, and I'm wondering if there's a bug involved in using SpaceClaim.
    • Subashni Ravichandran
      Hello smjang
      We thank you for sharing your feedback. We will share your idea/input with the product development team.
      • smjang
        Subashni Thank you for answer. I hope this feature is added. We ask that it be included in the next development process.
