Discovery Import
Discovery Import
Discovery Trial Installation Failure
    • alex.austin
      A customer receives the below error when installing Discovery's trial. He got around the problem by replacing the 7z.exe executable with the 64-bit version (the version that came with the download was a 1kb size file).
      Unsupported 16-Bit Application
      The program or feature “??C:UsersjmeyerAppDataLocalTempans_install_tmp77127zip7z.exe” cannot start or run due to incompatibility with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
    • Brian Bueno
      Alexander
      Advise the customer to use a 3rd party compression program for unzipping.  I recommend 7zip
