January 16, 2019 at 8:52 am
January 16, 2019 at 9:58 am
Naresh Patre
Ansys EmployeeHello Anja
I will check with the licensing team and let you know.
January 17, 2019 at 4:16 am
Naresh Patre
The message "Licensed number of users already reached." in the snapshot that you shared seems to indicate you need another Discovery license, that the 1 license is in use and you are trying to do something that requires an additional license.
January 17, 2019 at 7:36 am
Anja
SubscriberGood Morning Naresh,
The customer has opened one project in Discovery Ultimate and tries to solve it with Polyflow in AIM. The second picture also shows that there are some problems with Polyflow in AIM. Does the customer need a different or additional license?
Kind regards
Anja
January 17, 2019 at 10:27 am
January 17, 2019 at 12:51 pm
Naresh Patre
Can you get all the files from %temp%.ansys folder? Please send it to ansys-discovery-support@ansys.com .
January 17, 2019 at 4:34 pm
Anja
SubscriberHello Naresh,
can you explain me, why you need the files? Can't you reproduce the error? I can send you the example, if you don't have one.
Kind regards
Anja
January 18, 2019 at 5:39 am
Naresh Patre
I was able to solve the medical tray example using floating as well as subscription license without any issue. If you have an example to reproduce the issue, please send it.
January 25, 2019 at 8:00 am
Naresh Patre
Ansys EmployeeThis has been confirmed as a defect and bug 77219 has been submitted for the same. I will let you know once it gets resolved. Unfortunately, there doesn't seem to be any workaround other than using subscription license at the moment.
- The topic ‘Discovery Ultimate -Polyflow’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- How to do the snap fit insertion FEA?
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
2542
933
787
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
