Discovery Import
Discovery Import
Discovery Using Enterprise License
    • nmorris
      Why is my Discovery Ultimate pulling my Enterprise License? I thought these were separate licenses.
    • Brian Bueno
      N. Morris
      Which license are you referring to specifically?
      Is your installation of Discovery Ultimate licensed through a floating enterprise license or should it be running off a subscription?
      • nmorris
        Brian Bueno It is a floating Discovery enterprise license. When I open Discovery Ultimate, it is pulling the Mechanical Enterprise license.
      • Brian Bueno
        N. Morris
        Are you using the latest version of Discovery (2019 R2)?
      • nmorris
        Brian Bueno No I am using 2019 R1. Why would that make a difference which license it is using? I verified in the license preferences that the Discovery Ultimate Enterprise license is above the Mechanical Enterprise License.
    • Naresh Patre
      Hello N. Morris
      Can you send the diagnostics file to look into this issue? Details about gathering the diagnostics file are mentioned in below post. Please send them to ansys-discovery-support@ansys.com
      Discovery Enterprise licensing: Gathering diagnostic information - Knowledge Base - Ansys Discovery Forum
    • Naresh Patre
      Hello N. Morris
      In your license preferences, please also move Discovery Ultimate Enterprise to the top of the PrepPost tab. That should resolve the issue.
Viewing 3 reply threads
