April 17, 2023 at 10:51 am
Lukas Bülow
SubscriberHi Guys,
I have a Problem with PyAnsys scripting, I need a command or codeline for the Wrap-Tool in Ansys. For every Command in "Construction" i could simply use the Record Function of Discovery but for the Wrap-Command which is in "Prepare" this does not work.
I've also read about a Wrap-Command that works with the Project-Tool (which would be nice because this works via the "Construction" Tab) but i cannot find the "Wrap" option there.I just want to Wrap a 2D-Curve around a cylindrical Object via Scripting.
I Really Hope someone can help me !
Thanks ! -
April 20, 2023 at 5:02 am
Naresh Patre
Ansys EmployeeHello @Lukas
I have the below commands from SpaceClaim scripting. I hope they will work in Discovery as well:
option = WrapOptions()
option.Extrude = True
option.Imprint = False
object = Selection.Create(GetRootPart().Bodies[0].Faces[4])
target = Selection.Create(GetRootPart().Bodies[1])
Wrap.Create(target,object)
Naresh Patre
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5370
3363
2471
1310
1020
