December 3, 2020 at 12:44 pm
k.katayama
SubscriberHello.
I have a problem opening DiscveryLive or SpaceClaim.
The programs just shuts down without any message after I type in my email address and password.
This happens with my desktop computer on which I used to use the programs, but it doesn't happen with my laptop which I have been using rately for convenience.
I have a subscription license and I don't remember there is a ristriction on how many machines I can run the programs on.
Please let me know if this is a licensing issue.
If it's not a licensing issue, can you tell me what the potential issue might be.
Thank you .
December 3, 2020 at 1:23 pm
Naresh Patre
Ansys EmployeeHello Kohei This is a known issue with 2020R2 version and the solution to overcome this problem is mentioned in the below article Discovery - Unable to start SpaceClaim or Discovery after login Please let me know if you still face any issues with launching the application. -
December 7, 2020 at 1:04 am
k.katayama
SubscriberHello Naresh Patre
Thank you for your help.
However, I cannot find the option, [-ActivateLicenseEntitlement
]. Similar option that I can find is [-SetActivationUser
], but I guess it assigns a user to a license. (Also I don't know what the Discovery account name is exatly.) Is there any way that the solution mention in the article is not complete or up to date?
Thank you.
December 9, 2020 at 12:46 am
k.katayama
I was able to try to manually activate the license on the device, but I got the following result on the command prompt.
Could you tell what the issue might be?
2020/12/09 09:35:43 DENIED
1/1/1/1 :: 6080 FNE Activation Response Error: All entitlements have been activated for id -
ERROR: Unable to activate entitlement with activation id '', error:
FNE Activation Response Error: All entitlements have been activated for id -Thank you.
December 9, 2020 at 12:56 am
k.katayama
I was able to active the license on the device.
It turned out that I activated the account on another device which I dont recall, and I just had to release the account from the device.
Thank you.
- The topic ‘DiscoveryLive shuts down after signing in.’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1478
