February 28, 2017 at 9:27 am
Nikita
Ansys EmployeeWhy is there a discrepancy between the face area displayed in DM vs. Mechanical, and how to improve it?
March 17, 2017 at 10:22 pm
pgl
Ansys EmployeeThe area measurements shown in Mechanical are approximate based on the tessellation. The value shown in DM is calculated in the geometry kernel, and is very accurate. This can be improved further by increasing the Graphics Facet Quality in DM. It improves the faceting on the curved entities and captures it better. And hence it reduces the discrepancy of the geometric properties like area, length.
To change the setting, under DM, go to Tools // Options // DesignModeler // Graphics // Facet Quality and set it to a higher value (default = 5). Once it is changed, refresh the geometry in Mechanical.
A drawback to increasing this value may be longer attach times and slower geometry manipulation.
- The topic ‘Discrepancy between face area displayed in DesignModeler vs. Mechanical?’ is closed to new replies.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8808
4658
3151
1680
1470
