February 20, 2023 at 4:46 pm
mh.pial5
SubscriberI am designing a 4 turn toroid shape inductor on a polyimide susbtrate in order to study the inductance vs frequency graph. The core is a cobalt based alloy and it was added. Generally the inductance should drop to zero at higher frequencies but my model dose not have that drop. I ran the simulation upto 100GHz. What the reason for it ? Currnet applied: 1A
INDUCTOR DESIGN
BOUNDARY REGION
EDDY EFFECTS:
SIMULATED RESULT: (L vs F)
CORE PROPERTIES
February 24, 2023 at 12:16 pm
Navya C
Ansys EmployeeHi mh.pial5,
Why do you think inductance should drop to zero at higher frequencies? It is inversely proportional to the frequency. Do you mean absolute zero?
What is your reference here?
Navya
- Maxwell, HFSS or Q3D?
- Error
3694
2558
1765
1234
590
